will not close pc contactor
lift has no functions, travel,lift, horn inop. pc contactor will not close. have good power and control fuses and battery is at 26vdc. when key is turned on icon on display blinks 9 times with a pause and then repeats. lift has no keypad, just keyswitch. any ideas?
  • Posted 2 Oct 2014 03:14
  • By forkdoc
  • joined 20 Sep'14 - 13 messages
returning to customer on Monday. I will check that. I appreciate the feedback.
  • Posted 4 Oct 2014 05:36
  • By forkdoc
to insure you are getting the right error code pull the motor cover and look on the controller itself and there should be an LED light at one end of the connectors. See what it is flashing.
A blinking hour meter display does not guarantee anything.
But as was mentioned before error 9 can be 2 things.
ereverse button pressed or bad switch.
  • Posted 3 Oct 2014 20:23
THANKS! I will check panic reverse.
  • Posted 3 Oct 2014 06:24
  • By forkdoc
This is a problem with the Emergency Reverse switch. It can be faulty or if it is pushed in a start up it will throw this code.
  • Posted 2 Oct 2014 22:16
  • By Avatar
  • joined 23 Jan'14 - 4 messages
