Whats the best way to fit a Packing ring on a ram?
re sealed a tilt cylinder today on a nissan (well i thought i had) but the mast keeps creeping forward.
removed the cylinder and checked the seals and the packing rings (nylon- solid) that go either side of the o- ring looked a bit ropey.
how do you fit them without damaging them? i tried heating the new one's up in boiling water and still there a pig to fit. is there a tool needed?
they are very brittle and dont take kindly to screwdrivers.
  • Posted 26 Nov 2008 08:17
  • Modified 26 Nov 2008 08:19 by poster
  • By upliftUK
  • joined 17 Nov'08 - 42 messages
  • leicestershire, United Kingdom
kjghkjhkh
yes it was just a packing ring, the old one's that came off were solid. love to see them do it at the factory.
  • Posted 28 Nov 2008 06:31
  • By upliftUK
kjghkjhkh
i stick the composite seal in my pocket before i start to strip the ram. by the time your ready for it,it,s nice an warm. slip it on and **** a hoseclip over it for 5. then use hyd oil to slide it back in the cylinder. bingo job done
  • Posted 28 Nov 2008 03:27
  • By kevin_k
If its just a packing that goes either side of a o ring then cutting at a angle is a recognised way to fit,if it is a composite type seal which fits over a piston head with another rubber seal underneath then warming up in hot water is best then use a seal clamp tool(looks like a piston ring clamp/sleeve)for 1/2hr this puts it back in shape.
  • Posted 27 Nov 2008 18:58
  • By Herald
  • joined 3 Jan'07 - 128 messages
  • lancashire, United Kingdom
what a nightmare, tried again to do these backing ptfe/nylon seals and again fiting them caused them to distort and leak.
i rang the hydraulic firm that does our more specialised cylinders and they surgested i put a slit/cut across the ring at an angle. i tried that and it worked a treat!!! time will tell if it lasts.
  • Posted 27 Nov 2008 07:12
  • By upliftUK
kjghkjhkh
We heat them up in a pot of hydraulic fluid. It makes them pliable and then work them onto the rod with a screw driver. It works well for us.
  • Posted 26 Nov 2008 23:27
  • By duodeluxe
  • United States
duodeluxe
thanks mate, i must admit i think heating it up did more harm than good.
i've done loads in the past, but they've all been the split type so are dead easy.
  • Posted 26 Nov 2008 16:31
  • By upliftUK
kjghkjhkh
lube the piston up good and do it with my bare hands. no need to "heat" the seal, just get a good vise that wont scratch the cylinder to hold the cylinder rod.
I do it all the time....
but it is a "pig to fit"
  • Posted 26 Nov 2008 10:56
Morooka MFD20
UN Forklift FL20-32LNJX2
Morooka MFD20
