warning light
I am having an issue with two BT RRE160 trucks equipped with warning lights that do not function. Options turned on in parameters. Only have battery neg voltage to light. I have not traced out the positive side with a meter as of this moment. All connections appear to be okay with no visible breaks in wires. Trucks are equipped with shock watches. These are newer trucks and these have not worked since shipped from factory. Any help would be appreciated.
  • Posted 7 Jul 2012 13:48
  • By ross_g
  • joined 12 Jul'05 - 18 messages
Your well covered for the RRE then.
Hopefully you will have version 010 or even 012 installed.
Version 010 is very stable & greatly improves the reach function & control, version 012 adds improvements for OTP / safety plus option.
  • Posted 10 Jul 2012 18:10
  • By Forkingabout
  • england, United Kingdom
yes , I have the manual. I also have the usb connecting box for computer hook up. Did not take note of the software installed in equipment.
  • Posted 10 Jul 2012 11:02
  • By ross_g
P5 is the flashing lamp.
You got the manual for the RRE?
Is your Truck Com lead USB?
What software package these RRE's running?
260038 - ****, What's the **** number?
Version 010 or 012 is what you want to be running.
  • Posted 10 Jul 2012 07:44
  • By Forkingabout
Found the issue today with the warning lamp. P17 was hooked up to light. Hooked up p5 to light and everything works fine now. Both p5 and P17 are designated warning lamp connections.
Your post just came in Stating the same thing that i found today.. LOL
Thanks for your assistance
  • Posted 10 Jul 2012 07:26
  • Modified 10 Jul 2012 11:15 by poster
  • By ross_g
Those parameter settings are fine.
Wire number 98 in connector X131 position 36 in the plug is the warning lamp output from the A5 MCU under the floor with the pedals on.
The warning lamp is P5 - you had the plastic roof panel down & checked its been connected to the right socket in the roof?
From on top of the roof using a 4mm allen key & torx 20 screwdriver, first remove the silver panel on the left ( 2 allen key bolts ) then undo the torx 20 screws while you support the plastic roof panel, the plastic panel will drop down & allow you to get at the connectors, the connectors will be numbered.
Also what software package is it running?
260038 - ****, whats the **** part of the package number?
  • Posted 10 Jul 2012 01:32
  • By Forkingabout
Using TruckCom TE ver2.8 I turned on parameter 1112- 1 representing 0n
para 106 set to 1 - 1 flash sec Used BT can key
Para 115 set to 128 ( truck started up) Used BT Can Key.
Truck is equipped with lift , tilt sideshift. No cab tilt
Model RRE160
Serial 617808
Still no warning light function
  • Posted 9 Jul 2012 07:10
  • Modified 9 Jul 2012 20:24 by poster
  • By ross_g
Are you sure the lamp isnt working, depending how it was set it can stay OFF until the hydraulic functions or traction is in action, if the truck is just stood still the lamp doesnt flash.
Ive been called out to a RRE for this very fault, customer felt embarrassed when he released.
Factory parameter 1112 needs to be switched on for the warning light & you can only do this parameter with BT Truck Com software.
Parameter 106 sets the flashing frequency
Parameter 115 sets when the lamp will flash
Parameter 106 & 115 you can change with a BT can key.
What hydraulic functions does the truck have, I need to know so I can tell you what the parameter should be set to.
Lift, reach, tilt - has it got sideshift? 5th hydraulic function?
You got a serial number for either truck?
  • Posted 7 Jul 2012 21:21
  • By Forkingabout
edition #1276 - 9 April 2026
In this week’s Forkliftaction News , we continue our coverage of LogiMAT 2026 held in Stuttgart with a rundown of some of the biggest product launches at the event which achieved record exhibitor and visitor numbers... Continue reading
