Very hard cold start
Have to crank long time several times to get lift to start. Once warm lift start easy. Happens every morning. Fuel lock off solenoid working & has been cleaned, LP fuel lines clean, no leaks. Battery is strong.
  • Posted 18 Dec 2012 13:38
  • By NWLift
  • joined 18 Dec'12 - 1 message
  • Washington, United States
After sitting overnight and acting the way it is, I suggest you check the condition of the large diameter vapor hose coming from the regulator and spanning over to the metal pipe near the valve cover. These hoses will sort of "unravel" or split due the the robust vibrations of the engine.
A hose with a split in it can completely empty of all propane vapors after sitting overnight and the split will made it slow to draw fuel out of the regulator at cranking RPM.
You might have to remove the hose for a thorough inspection.
Are you pressing the accelerator pedal when you do your cold start?
If not, you may want to try holding the accelerator down while cranking as that can make it easier to draw fuel out of the regulator.
  • Posted 18 Dec 2012 15:31
  • By L1ftmech
  • Tennessee, United States
Autolift E180AT36B-D5-180
Morooka MFD20
November 3-4 2026 - Houston, United States
edition #1289 - 9 July 2026
In this week’s Forkliftaction News , we continue our coverage of CeMAT Australia with a report on how the lack of local after-sales support and service is hurting new foreign entrants into the Australian market... Continue reading
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
