valve park brake release
my front axel brakes will not release. is there a valve park brake release for this unit and if so where is it located ? "the serial number is 0160039087
  • Posted 18 Oct 2023 23:45
  • By dan_baiza
  • joined 18 Oct'23 - 1 message
there is a way to release the brakes manually but then you wouldn't have any brakes at all, the manual release is for towing the unit only.
it sounds like either the park brake switch is not working or there is some issue with the brake valve. This brake units are inside the front drive axle, there are two brake units that are hydraulic controlled. The brake valve is inside the dash area above the brake pedal assy. It is not servicable, if there is any problem with it it has to be replaced.
You REALLY should call a JLG service tech on this one.
  • Posted 22 Oct 2023 15:27
  • Modified 22 Oct 2023 15:28 by poster
Ncn 110TH
Ncn 110TH 2015
Crown WP302020
