Valve lash
Is there an adjustment procedure or adjusting the cam tappets, or valve lash in these Mitsubishi engines? Engine has a new head on and valves are tapping
  • Posted 23 Apr 2010 01:47
  • By Barfly_olaf
  • joined 10 Oct'09 - 81 messages
  • Nova Scotia, Canada
SEMPER FIDELIS
Turn the motor so the cam lobe is pointing away from the rocker arm and stick a feeler gauge in between the lobe and the rocker. Should be.006" on intakes and.010" for exhausts. Do them one at a time and rotate motor to position the lobes properly as you do each one. Loosen nut and turn screw on the rocker to make adjustments.
  • Posted 23 Apr 2010 22:14
Tusk 350CGH20
Crown WP302020
