Truck is not getting on
Check battery voltage is ok
Check all fuses
Check emergency switch is ok
Check display visually is ok, trying to turn on, but display is not getting on
Check emergency switch input voltage 24v is ok, output 24v not getting
If emergency switch coil by giving separate 24v ,output 24v supply is coming,relay no supply, display wiring no supply
Check relay & it's wiring ok,for relay no supply coming
For display wiring no supply coming
If any one have service manual or wiring diagram
  • Posted 11 Sep 2021 00:29
  • By ragu_k
  • joined 25 Jul'13 - 19 messages
  • karantaka, India
What type of key pad does it have? Email me a picture of the keypad. Email address is my signature. Not sure if I can help as I have never seen a WP with keypad but I will try. There should be a way to by pass it like the Info Link modules.
  • Posted 11 Sep 2021 12:50
  • By 1CrownTech
  • Washington, United States
1crowntechnician@gmail.com
Key switch no have
Keypad on display type
  • Posted 11 Sep 2021 07:07
  • By ragu_k
  • karantaka, India
Key switch resistance is ok ?
  • Posted 11 Sep 2021 07:01
  • By Triggs
In machine no tow switch
Visually check all connections are connected
For emergency switch coil wiring supply is missing
For coil wiring from where it's coming???
For relay wiring no supply, display wiring also no supply,I think emergency switch coil wiring supply get then circuit will work
If you have any manual kindly send us for further inspection on this truck
  • Posted 11 Sep 2021 06:13
  • By ragu_k
  • karantaka, India
If it has a drive/tow switch, make sure it's not on or the plug disconnected.
  • Posted 11 Sep 2021 03:35
  • By 1CrownTech
Linde Material Handling
SMV (Konecranes) 12-1200B
Taylor THC500L
