Trouble Starting Nissan with K25 eng
Nissan forklift hard to start. Cranks over fires and fully starts occasionally. Rebuilt Nikki vaporizer and replaced cam, crank, fuel pressure, and MAF sensors because of codes. (Yes OEM cam and crank sensors). Injectors seem to be working properly and cleaned throttle body along with holder assembly. Getting spark, have correct fuel pressure at vaporizer. Will start every time if you block off the air intake while cranking creating more vacuum. Any suggestions appreciated.
  • Posted 7 Feb 2019 07:54
  • By nick_l
  • joined 7 Feb'19 - 2 messages
got a OBD handset?
might just need to go in and clear out and stored codes and then reset the air/fuel ratio so it can relearn it.
  • Posted 7 Feb 2019 18:12
SMV (Konecranes) 20-1200B
Terberg YT222
