transmission trouble
forklift was operating correctly.reversed to park.shut off machine and restarted later.will not move forward but does move in reverse.looking for repair options. Lift was low on trans. fluid.We refilled to correct level.There are no leaks, where did fluid go ?
Toyota 7FGU30
SER # 65113
  • Posted 8 May 2024 01:23
  • By Al_Dehnert
  • joined 8 May'24 - 2 messages
al dehnert
There's a data tag printed on top of the transmission. Model and serial number. Have to specify this and model and sn to dealer for parts. Is this a 2 speed forward model? If so, rough or abrupt shifting from 2 nd to first will cause clutch pack damage. Operators should never downshift in motion or it blows apart the clutch packs.
  • Posted 10 May 2024 02:46
  • By ron_k
  • joined 2 Apr'15 - 128 messages
  • North Dakota, United States
4kliftman
How do I find the model or part # for transmission assembly complete with torque convertor ?
  • Posted 10 May 2024 02:41
  • By Al_Dehnert
al dehnert
Check at the trans solenoids for power. You have reverse so check the other for power. If you have no power at the solenoids then check your shift lever. Sometimes the contacts get dirty and won't allow power to solenoids. Have to replace shift lever if it's electric switch.
  • Posted 10 May 2024 01:57
  • By ron_k
4kliftman
