Transmission replacement cost
I am working on a quote to replace trans on a H155 (Yale GDP155).
Does anyone have an Idea what the dealer or shop would charge for this?
Thanks
  • Posted 15 Jul 2020 04:06
  • By JayR
  • joined 10 Nov'15 - 38 messages
Depending on the cost of the transmission, 8 to 10 thousand. You did not say if it has 2 or 3 gears. Depending on the model year you will be looking at about 45 to 60 hours of labor. They will want to replace oil cooler or at least flush along with lines and filter. There will be additional repairs due to old hoses and other things that were never done. Total cost would be around $20,000. This will also depend on your location. Have you had test completed stating the transmission has failed? Make sure the inching adjustment is correct. This is a common problem alot of techs overlook. Good luck
  • Posted 17 Jul 2020 23:33
  • By Fishmech
  • Virginia, United States
Komatsu FD25T17
Crown SX3030TT4250
Hyster
Komatsu FD25T17
Crown SX3030TT4250
