Transmission pump
I think the trans pump may be going out in my old yale G83P. It's squealing when I crank it up, lift wont move until the squeaking/squealing stops. Cheapest I have found is $900 for a hydraulic pump no bigger than my fist and the forklift is barely worth 3x that. Would it be possible to use another brand of pump as long as it's the correct gpm and I can get it to fit? The pump is a YT5067666-01 but I have not been able to find the gpm or any other specs on it. The lift is 5k capacity if that helps any. Thanks !
  • Posted 31 Aug 2021 04:16
  • By Wayne_Webb
  • joined 2 Aug'20 - 14 messages
Thank you very much sir!
  • Posted 3 Sep 2021 05:28
  • By Wayne_Webb
Wayne,
If you know who manufactures the pump usually they are three times cheaper. You may have a problem with the pressure relief. They will squeal until it pops into place. Pull it and check for contamination.
  • Posted 3 Sep 2021 05:18
  • By Fishmech
  • Virginia, United States
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Maxlion FB30LI
USD1
Maxlion FB30LI
Michel Denis Michel Denis
