Transmission fluid overflows out of breather cap when moving loads.
When this machine warms up and starts moving heavy loads the transmission oil starts to come out the breather cap. Tried changing the oil (Dex 3) but problem still continues.
This machine is used outdoors and loads are lifted off the ground. Nothing is being pushed with this machine.
  • Posted 28 Jul 2015 22:26
  • By altustech
  • joined 10 Oct'12 - 21 messages
  • New Jersey, United States
is the engine speed governed properly ???. seen this if the engine is going faster than it should and whipps up the oil too much
  • Posted 29 Jul 2015 03:02
  • By kevin_k
what is the oil level?
when cold? (before work)
when hot? (after use)
since you check the oil with it running have you checked inside the dipstick tube to see if there is any foaming when it starts coming out?
  • Posted 29 Jul 2015 00:53
Terberg YT220
JLG G12-55A
Danville, IL, United States
Terberg YT220
JLG G12-55A
