Transmission diagnose
I have a hyster h50xl. It travels forward and reverse. The problem is that it travels extremely slow. Is there a actual service and repair manual that I can download to try and repair this unit? Or a test procedure that I can follow? Please help!!!
  • Posted 26 Nov 2019 05:44
  • By Lenthetech
  • joined 25 Oct'19 - 10 messages
  • Alberta, Canada
Before you do anything else, check to see if the transmission filter is tight. I've run into several of these where the filter is less than hand tight. Not sure if it's due to vibration or a mechanic who doesn't know what he's doing. The trans will slip and delay going into gear if the filter is loose enough.
  • Posted 13 Dec 2019 02:28
  • By lumberjack
  • joined 27 Jul'07 - 192 messages
  • Maryland, United States
