Trans not pulling
Hi all. I have a H50XL trans that began boiling fluid out the dipstick tube after 20 minutes of operating and then it would not pull in either direction. If they let it cool it would do it again. Now I have it at our shop and it will not pull at all hot or cold. Engine idle speed is up also. Can anyone guide me through some good troubleshooting?
Thanks,
  • Posted 26 Nov 2008 06:21
  • By TimM
  • joined 26 Nov'08 - 7 messages
Thanks! Tim
drain the oil out.look at the strainer.i'll bet the oil is black and the strainers full of bits.sounds like clutch packs shot but why?check for pack pressures, check for cooling circit pressure,check charge pump pressure,torque convertor pressure.usual stuff.
recently had very similar problem on a h7.00xl.the customer had a radiator damaged and decided to intall his own non hyster rad from god knows where.problem was the flow rate through the tranmission cooler was much less on the new rad than the old one.result was that the oil did boil and you can guess the rest.
  • Posted 26 Nov 2008 09:47
  • By tugmaster
  • joined 25 Aug'08 - 73 messages
  • United Kingdom
Sue Tomic Sue Tomic
Crown SX3030TT4250
Toyota 8FD45
