Trans Brake Hot , Fricton reduced
Truck is flashing,
Trans brake Hot
Friction reduced
  • Posted 12 Jul 2014 01:26
  • Modified 12 Jul 2014 01:27 by poster
  • By ufl1996
  • joined 22 May'14 - 5 messages
  • Tennessee, United States
First off there are two speed sensors one is the TISS the other is the TOSS. The TISS has 3 wires, the TOSS has 4. Either one can cause this problem. You need a service level password to get into the dash setup.
  • Posted 8 Jun 2017 07:13
  • By BREWSKI
I have the same thing happen I checked wiering. All good got new sensor still doing the same thing. Barely moves and forwards. Moves in reverse but flashes on and off. How do you calibrate it.
  • Posted 8 Jun 2017 01:34
  • Modified 8 Jun 2017 02:02 by poster
  • By jordan_b
  • joined 26 Aug'14 - 4 messages
there should be a fault code on the dash or will say trans braking, this is on the VX models only..
  • Posted 30 Dec 2014 15:56
  • By YaleTechnician
  • joined 11 Dec'13 - 18 messages
Have a Yale glc050 that is doing same thing. Did TOSS sensor fix problem?
  • Posted 30 Dec 2014 04:36
  • By Boeing
  • joined 30 Dec'14 - 1 message
you have a bad TOSS sensor on transmission. It sits or right side of top of trans, Its a 4 wire connector. check for loose connection, if ok, replace Toss sensor. once you do that ,calibrate transmission and you should be ok.
  • Posted 1 Aug 2014 15:25
  • By YaleTechnician
Do you have the optional Duramatch (the Hyster name) trans which automatically decelerates the lift when you take your foot off the gas?
  • Posted 12 Jul 2014 11:04
  • By bbforks
Michel Denis Michel Denis
