TRANNY FILTER DEVELOPS LEAK
I HAVE A CUSTOMER WITH A HYSTER S60XM D187# THAT KEEPS CHANGING TRANSMISSION OIL FILTERS EVERY 45 DAYS DUE TO A HOLE DEVELOPING IN THE FILTER ITSELF. AS FAR AS I KNOW THIS TRANNY DOES NOT HAVE A BREATHER SO WHERE ELSE SHOULD I LOOK?
  • Posted 31 Jul 2009 03:11
  • By glenn_levit7
  • joined 10 Jul'07 - 78 messages
Montacargas, Tequila y Limon!
If you use a OEM filter it will not leak. I'm a service manager at a hyster dealership. I see this all the time. If you put on a OEM you will not have the problem.
  • Posted 28 Oct 2009 09:24
  • By jeremy_p
  • joined 1 Jul'09 - 4 messages
  • Washington, United States
Same with Perkins!!
  • Posted 18 Sep 2009 08:04
  • By danny_k
sounds like just the opposite of how we used to keep track of oil changes for old Detroit diesel 3 cylinders. when it STOPPED leaking, it was time to add/change oil.
  • Posted 18 Sep 2009 07:55
LOL, the leaking engine filter is how I keep track of pm's.
If it leaks, it's time to drop the oil :-)
  • Posted 18 Sep 2009 04:37
  • By mike_n
  • Alberta, Canada
Ive got the same thing.Use Wix filters they last longer.Engine will do the same leak at 30 to 45 days on a aftermarket filter.
  • Posted 8 Aug 2009 22:03
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
just had a thought. check that the engine is not overspeeding/overevving. that can cause too high a pressure in the transmission. easy first check
  • Posted 3 Aug 2009 05:14
  • By kevin_k
pressures too high. remove the control block and make sure all the springs and spools are ok. must be something sticking
. can,t quite remember but i think the filter is in the lubrication circuit. i,ll look it up if you need
  • Posted 1 Aug 2009 20:48
  • By kevin_k
hello Mike, yes it's just a pinhole at the seems that develops. my customer also states that when he installs a new filter it usually starts to leak from the bottom like when it's the gasket or not tighten enough. he then gives it a few turn to tighten and that stops that leak. then 30 - 45 days later the pinhole develops at the seems. what do you think?
  • Posted 1 Aug 2009 06:43
  • By glenn_levit7
What kind of a hole?
Is the filter popping/splitting open?
Just a pinhole?
I've had tons of these filters leak at the seam, over the years...
  • Posted 1 Aug 2009 04:07
  • By mike_n
  • Alberta, Canada
Chandler, United States
Philadephia, PA, United States
Aichi SR10C1SM
Tusk 350CGH20
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
