Toyota 8FGCU25 Error Code AD-7
After replacing a damaged multi-function display we are now getting fault code AD-7. We can install the old display and the code disappears. The service manual clearly states that a "Engine and display ECU information clear" is required, nowhere in the service manual does it explain how to perform the procedure. Any advice or help would be greatly appreciated.
  • Posted 24 May 2016 00:19
  • By JP660
  • joined 20 May'16 - 2 messages
  • Illinois, United States
For clear this error code AD_7
You should pass in to monitor panel and go to settings 5- and clear it.
In Toyota shop manual book you can see it.
If you need guidance just message me on telegram messenger.
+989395094590
  • Posted 29 Jun 2025 05:43
  • By Afshin
  • joined 29 Aug'23 - 34 messages
  • Iran, Islamic Republic Of
Hi have code 71-1 ad-7 Toyota
8fdu30 50302 f/r take delay in the engage
[email address removed] thank hope you help me happy weekend
  • Posted 13 Nov 2022 03:43
  • By armando_g
  • joined 11 May'18 - 48 messages
grgarryciencia@aol.com
forgot to mention if your old display works go into option set mode and write down how options are set then install new display and set to the same
  • Posted 3 Jun 2016 13:01
  • By fixnproblems
  • joined 19 Jan'13 - 66 messages
hope this helps, but make sure the two black relays in the fuse box are working correctly, then you must enter into the option set mode and set options to factory ordered specifications
  • Posted 3 Jun 2016 12:24
  • By fixnproblems
send your email address and i'll send you something
  • Posted 1 Jun 2016 00:21
  • By erik_h
  • joined 12 Sep'07 - 18 messages
  • Tennessee, United States
"Oh My God, You'll Work on anything"
Simply disconnecting the battery negative for more than 10 seconds clears any codes that are not active. If the code reappears, you have a CAN communication issue. If its only with the new board, then check the board connections.
  • Posted 31 May 2016 01:31
  • By ramon_m
  • joined 30 May'14 - 42 messages
Libiao Robotics
JLG G12-55A
Maxlion FD50T
JLG G12-55A
Maxlion FD50T
