toyota 7fgu(15?)
I Have a toyota 7 series that will not stay running. as soon as you release the key it dies.... if you hold the key in and unplug the starter coil, the truck will appear to idle just fine. I Have checked the "usual" distributor connector has 12 volts to it. the single wire oil switch (by the fuse box) has 12v to ground. I swapped as many relays, between this truck and another just like it.
Oh Yeah, This truck died right after a " tune up" plugs/wire/cap/rotor etc.... HELP!!!
  • Posted 25 Nov 2008 07:58
  • By NoBody
  • joined 21 Mar'08 - 11 messages
  • Virginia, United States
A true friend knows what it is!
I have had that key switch melt Rich
  • Posted 26 Nov 2008 07:23
  • By rich_k
  • joined 30 Oct'07 - 108 messages
It sounds like the key switch is no good and is probably just a coincidence that it was just tuned up.
  • Posted 26 Nov 2008 00:28
  • By duodeluxe
  • United States
duodeluxe
