toyota 7fgcu45 no start
I have a Toyota forklift that has a no start problem. the engine light on the far right of the dash will flash 8 times then pause then 4 times. I have tried new grounds extra grounds. basically what I found is that the coil is getting power only when cranking. so I checked the relay it has constant power the governor ecu drops off the ground when your not cranking so it will fire up then die immediately when you release the key. I tried a new key switch. the problems seems fix its self every so often but it mainly does not stay running. any ideas would help I have hit a lot of dead ends
  • Posted 24 Dec 2013 04:34
  • By kyle_a
  • joined 24 Dec'13 - 1 message
  • Washington, United States
run a 10 gauge ground wire from battery negative to alternator housing and that will fix it, there was a campaign sent out from toyota on this, hope this helps
  • Posted 14 Feb 2014 15:24
  • By fixnproblems
  • joined 19 Jan'13 - 66 messages
