toyota 6FBR10 HELP!!me!!!
hi peeps,
i have enquires about which type of oil is require for the respective model(6FBR10).there is a cap with the word "oil" written on top of it. but i have no idea what type of oil to use..Does anyone knows?? and can u peeps share more information about the maintenance of the forklift.(what hydralic oil to use , motor oil,whatsoever)?? helP!!!
THANKS ALL xxxx
  • Posted 4 Apr 2006 15:04
  • By zhoo_j
  • joined 4 Apr'06 - 3 messages
  • aa, Singapore
a quick way to check if u have enough oil is to raise the mast fully and watch for erratic movement (jumping, studdering, vibration, etc)
if it extends fully and smoothly its oil level is most likely fine
  • Posted 13 Apr 2006 06:59
  • By justinm
If the maximum lift height of the machine is 3000mm then the hydraulic level should be adjusted to the 30 mark on the hydraulic level stick.
  • Posted 6 Apr 2006 04:46
  • By adrian_w
  • joined 18 Nov'05 - 33 messages
  • East Yorkshire, United Kingdom
Premier Mechanical Handling,
Hull.
UK
does that mean i don't have to refill the tank? it's reading is at 30
  • Posted 5 Apr 2006 14:40
  • By zhoo_j
  • aa, Singapore
The oil you require is Hydraulic oil ISO VG32. The mast needs to be lowered and the markings on the cap stick indecate the correct oil level for the maximum lift hieght. I.E 40 = 4.0mtrs lift.
  • Posted 5 Apr 2006 06:04
  • By adrian_w
Hull.
UK
HELP =0
  • Posted 4 Apr 2006 15:05
  • By zhoo_j
  • aa, Singapore
Linde Material Handling
Maxlion R2D35
Mitsubishi FGE35AT
