totally lost
Yale H30XM
Totally lost. Have 2001 yale reach truck. Initial problem would mass would not go down. Then truck quit all together. This is the code it I have. 0271 can not find code in manual
  • Posted 11 Jan 2024 09:50
  • By Chuck_Bates
  • joined 11 Jan'24 - 3 messages
  • Virginia, United States
Chuck Bates
Do you have the correct model and serial number.
  • Posted 13 Jan 2024 04:44
  • By Scott_
  • joined 16 May'21 - 332 messages
Scott
It is a yale stand up reach truck 36 volt
  • Posted 13 Jan 2024 03:32
  • By Chuck_Bates
Chuck Bates
Thank you so so much
  • Posted 13 Jan 2024 03:31
  • By Chuck_Bates
Chuck Bates
Down is gravity fed..so as long as down coil getting power and ground...valve issue or mast bearings..if machine quit while trying too many times..may have tripped breaker or blown fuse...verify battery voltage first..then follow flow of current to each contactor/solenoid then if voltage getting all the way through check motor
  • Posted 12 Jan 2024 16:12
  • Modified 12 Jan 2024 16:13 by poster
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
I WOULD like to help you but check your model this is not a reach truck the model is for a hyster sit down gas truck.
  • Posted 11 Jan 2024 10:59
  • By Scott_
Scott
edition #1281 - 14 May 2026
