Tilt and side shift
E16-02 H2X324P01952
I know the pump motor has issues but..
Lift works 90% of the time
When you pull tilt or side shift lever the SCR hums and the motor wants to turn but doesn't. sometimes the motor will jump and then run. Other times just the hum of the scr. I took the 4th function plug and tried it on both the side shift and tilt valves both functions work. I tried changing out the lift controller and the problem remained the same.
  • Posted 16 Aug 2018 05:34
  • By Grant95
  • joined 8 Feb'18 - 10 messages
  • Minnesota, United States
It sounds like the motor only runs above a certain threshold. Your tilt and sideshift may be below this threshold so the motor is not rotating. If the lift only works 90% of the time it makes sense to fix the motor.
  • Posted 16 Aug 2018 06:44
  • By BREWSKI
Taylor TXB180S
JCB 533-105
