Tilt and side shift
E16-02 H2X324P01952
I know the pump motor has issues but..
Lift works 90% of the time
When you pull tilt or side shift lever the SCR hums and the motor wants to turn but doesn't. sometimes the motor will jump and then run. Other times just the hum of the scr. I took the 4th function plug and tried it on both the side shift and tilt valves both functions work. I tried changing out the lift controller and the problem remained the same.
  • Posted 16 Aug 2018 05:34
  • By Grant95
  • joined 8 Feb'18 - 10 messages
  • Minnesota, United States
It sounds like the motor only runs above a certain threshold. Your tilt and sideshift may be below this threshold so the motor is not rotating. If the lift only works 90% of the time it makes sense to fix the motor.
  • Posted 16 Aug 2018 06:44
  • By BREWSKI
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
Powerfleet
AI-enabled safety and compliance solutions for material handling operations.
May 20-21, 2026 - Melbourne, Australia
August 19-21, 2026 - Bangkok Thailand, Thailand
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
