throttle goes wide open
Need help, turn truck on, throttle goes to full open replaced tps does same thing. Can't pull any trouble codes.
  • Posted 11 Oct 2015 03:43
  • By louis_l
  • joined 11 Oct'15 - 7 messages
  • Wisconsin, United States
Turns out bad ECU. Thanks everyone for the good advice.
  • Posted 17 Oct 2015 00:55
  • By louis_l
in particular, check that the 2 black wires [that looks like a ground, and is attached to the exhaust manifold studs with what looks like an eye lug, this is actually a thermal resistor] for the ecu's temp sensor has not had any thing tied into it, I have seen times when people thought that it was a ground lead and tied some added device into the wires, one of these wires is connected to the black and white wire going back (coming out of) the ECU, that is common to both the temp sender for the ECU (not the dash gauge, it has it's own temp sender) and the accel. pedal position sensor.
  • Posted 15 Oct 2015 21:26
  • Modified 15 Oct 2015 21:44 by poster
so this truck (from the serial number) is the s15-g system, your best bet is to bite the bullet and call the Cat or Mitsu dealer, and tell them you will need the persons that know how to set up an accel pot with the laptop in this version [s15-g] truck.
you might first make sure nothing has gotten tied into any of the wires that feed into the circuits monitored by the ECU. Usually this truck will only low idle [650rpm, normal idle is about 725/760] if their is an abnormality.
after you are sure the wires are 'clean' you might try a 'known good' ecu.
on this truck, there is a 'fuel trim' [vacuum control solenoid valve] with a red and white wires. DO NOT TEST these wires WITH A METER with the ECU connected.
  • Posted 14 Oct 2015 21:52
  • Modified 14 Oct 2015 22:01 by poster
Read it wrong AF83D00267
  • Posted 14 Oct 2015 03:19
  • By louis_l
serial #AF63D00267. WE put a new pot on and still does the same thing. Should I check the wiring from the pot. if so can you give me some suggestion.
  • Posted 13 Oct 2015 23:49
  • By louis_l
what is the serial number of your truck? (my guess is it is an af8xdxxxxx [x = number]
this is a 2003 truck with an s15-g emissions system.
4 flashes on this truck indicates a 'pedal sensor open error'.
check the accel pot.
  • Posted 13 Oct 2015 11:49
  • Modified 13 Oct 2015 11:49 by poster
So now I have code on dash light that flashes 4 times. Is that E04 of F04.
  • Posted 13 Oct 2015 02:39
  • By louis_l
G s e ground support. Have you plugged in and seen the inputs outputs in uptlme.you can check throttel and acc to see whats going on
  • Posted 12 Oct 2015 23:21
  • By alanmitsi
  • joined 8 Aug'13 - 151 messages
  • essex, United Kingdom
What is gse. this is a fly by wire. Maybe I'm not pulling the codes right. Can you tell me how?
  • Posted 12 Oct 2015 04:21
  • By louis_l
Would have thought a fault coe would be displayed have you used gse to see whats up.Check the throttel body.In al my time have never had to replace one.Have replaced many looms not that expensive and easy to do alan
  • Posted 11 Oct 2015 09:16
  • By alanmitsi
edition #1289 - 9 July 2026
In this week’s Forkliftaction News , we continue our coverage of CeMAT Australia with a report on how the lack of local after-sales support and service is hurting new foreign entrants into the Australian market... Continue reading
