CODE 90099 & 40107
CODES NOT IN SERVICE MANUEL SAYS "CAN IO INTERUPT FAULT" AND STEER CAN BUSS FROM CAN IO
  • Posted 13 Mar 2017 23:15
  • By MRLIFTOFNY
  • joined 11 Sep'08 - 51 messages
EMAIL ; MRLIFTOFNY@AOL.COM
Picture of the harness to be checked
  • Posted 6 Aug 2025 01:08
  • By Jerry_Sukhwa
  • joined 6 Aug'25 - 1 message
Jerrysukhwa
Check the resistance in the canbus loop. You can check it at the diagnostic connecter. Should be 60 ohms. If it is 120 ohms you have an open resistor. If the loop is open you will need to find the break. If it iws shorted you will need to find the short.
  • Posted 13 Mar 2017 23:32
  • By BREWSKI
Zhejiang UN Forklift Co., Ltd
