104-2 code
I have a machine with a 104-2 code. It has been having issues starting at -25C and colder with small pan heater. GM 2.4 LPG
It had a code 106-14 Map sensor mostly cold starts. This style of LPG is really lazy cold in comparison to the older styles.
  • Posted 14 Jan 2017 03:59
  • By TKOforklift
  • joined 24 Nov'07 - 30 messages
  • British Columbia, Canada
TKO Forklift and Equipment Repairs
Kamloops BC
250-819-6575
tkoforkliftservice@gmail.com
Yes I did. I found that the PCV was stuck closed and then caused excessive oil in filter housing saturating the MAP. I cleaned it with MAF sensor cleaner and ordered new sensor and PCV. Seems good now
  • Posted 3 Feb 2017 02:33
  • By TKOforklift
Kamloops BC
250-819-6575
Have you replaced the MAP sensor? Both codes are for MAP sensor errors.
  • Posted 3 Feb 2017 00:57
  • By BREWSKI
Mitsubishi FD200
UN Forklift FB25N1LZ1
Sue Tomic Sue Tomic
