Radiator R & R
Does the counterweight need to be removed to remove the radiator?
  • Posted 12 Dec 2016 12:53
  • By Ottofarm
  • joined 12 Dec'16 - 2 messages
Can not remember on this old truck. Look at the rear of the counterweight. Most had a single bolt on the bottom rear inside the tow pin hole. There should be two holes in the top of the weight. Use a lifting sling to pull. Your #5000 forklift is more than large enough.
  • Posted 17 Dec 2016 01:23
  • By BREWSKI
I was afraid of that. Is it tough to do? I have floor jacks, loader tractor and another lift truck rated at 5000#. Approximately how many bolts will I need to find before removing the weight. Thank you for all the help.
  • Posted 13 Dec 2016 12:06
  • By Ottofarm
You will need to remove the counterweight to pull the radiator.
  • Posted 13 Dec 2016 04:26
  • By BREWSKI
UN Forklift FGL25T
Taylor XC300M
New - Sale & Hire
Hyster
Sue Tomic Sue Tomic
UN Forklift FGL25T
Taylor XC300M
New - Sale & Hire
Hyster
