Intermittent accelerator
Wondering if anyone might know what is wrong with my ACE50 electric forklift. When you step on the accelerator the contact won't stay engaged. If you go very and I mean very lightly on the accelerator then it will stay engaged and you can move across the floor. Sometimes when you are going across the floor it will kick out too. I have already replaced all 3 of the little pots that are located in the box under the steering wheel. Don't know where to start again. Any help appreciated.
  • Posted 29 Nov 2016 04:50
  • By Potatolady
  • joined 29 Nov'16 - 1 message
  • Prince Edward Island, Canada
Not sure which controller system it has but going by the model number can i assume it has an AC controller?
If so then most likely the display will show an error message / code when the contactor kicks out.
It could be an accelerator pot or a component in the system causing the issue.
First off make sure the battery is fully charged and does not have any load related problems due to any bad cells or low electrolyte levels.
  • Posted 29 Nov 2016 05:50
Elwell-Parker ESI500-36
Terberg YT220
ROYPOW
