Additional hydraulics
C500Y55LPG
I need mote hydraulics on this lift. It has a vickers 222827 2-spool valve. There is one big plugged port on the valve near where the pump line enters. Can I maybe use that port for connecting another valve? Im hoping to get pressure out of there when not using any functions on the original valve. Otherwise I suppose I have to intercept the pump line before entering the original valve and feed it first through another valve..
  • Posted 1 Nov 2016 08:31
  • By christian_s
  • joined 25 Nov'15 - 24 messages
  • Pedersore, Finland
I have no idea were you will get one. It originally came in a kit from the manufacturer. You will need to work with the local dealer and see if it is still available.
  • Posted 4 Nov 2016 23:15
  • By BREWSKI
What poppet is that and where can I find one? Thanks!
  • Posted 4 Nov 2016 20:43
  • By christian_s
There is a through port on Vickers valves. To use it you must insert a milk stool poppet in the opening under the outlet fitting, if I remember correctly. If you do not install the poppet the pump will over pressurize and split.
  • Posted 1 Nov 2016 23:18
  • By BREWSKI
Taylor TE650S
Taylor TXB180S
