Little to no travel
E45Z-33, G108v02144B,
We have installed a new traction controller about a month ago, it had gotten wet and fried, has been running great ever since, this morning after hooking up battery and turning on.found hydraulics work great but little to no travel with no code. Powersteering comessage on contactor pulls in, brakes release, but foot pedal all the way to the floor and truck barely moves, display shows battery voltage and mode1 but no codes, can you help?
  • Posted 11 Oct 2016 09:24
  • By britain_w
  • joined 17 Jun'16 - 19 messages
  • Washington, United States
Mechanic
since the controller is still in warranty state being new i would call a hyster tech out and have him hook up the pc service tool and see whats going on.
OR remove the part and send it back and have it tested.
  • Posted 12 Oct 2016 21:49
Tried yesterday to change the modes but couldn't get out of mode 1, don't have the codes so can't access any of the options, it's been running fine on mode 1,
  • Posted 12 Oct 2016 01:26
  • By britain_w
Mechanic
try changing modes and set it to a higher mode
mode 1 is the slowest mode, while mode 4 is the highest performance mode.
see if changing modes changes the speed reactions
if you can access the service menu you can also change the travel speeds in each mode this way through the dash, or if you have the PC ETACC program you can change it or reset all settings to their default settings using that.
There is also a diagnostic menu you can access to see what the drive function is doing.
  • Posted 11 Oct 2016 10:45
Terberg YT220
Terberg YT222
Terberg YT220
Terberg YT222
Brussels Airport in Belgium, Europe is the world's largest sales point for chocolate, with over 800 tonnes of chocolate sold annually. This averages out to about 1.5 kilograms sold every minute.
