Timing Engine
Had a broken timing belt and suspect valves bent (not safe engine?) any one know timing setup and size/type of torx bit for head bolts.
  • Posted 4 Oct 2016 20:58
  • By johaanmikiel
  • joined 11 Aug'15 - 8 messages
  • east lothian, United Kingdom
arte et marte (twist to open)
Sockets are called XZN Triple Square. They come in a set. You might try a new timing belt before pulling head. Iam told belt breaks at start up or when key is turned of. Have had a belt break and did this and it worked. When belt is put on turn motor over manually. If valve is bent motor will only turn over so far. its worth a try.
  • Posted 19 Mar 2017 00:05
  • By edward_m
  • joined 11 May'15 - 111 messages
  • Posted 19 Mar 2017 00:04
  • By edward_m
Serial Number is H2X394W02194
Any one know the size of the Star Head bolts and the timing setup?
  • Posted 6 Oct 2016 17:54
  • By johaanmikiel
hello.
send serial nummber an I can help.
I think the engine i broken.
  • Posted 6 Oct 2016 16:02
  • By sjoold
  • joined 24 Oct'15 - 25 messages
  • Norge, Norway
Maxlion FD50T
Maxlion FDR45
Michel Denis Michel Denis
