gas vaporizer
Having a problem with gas vaporizer. Sometime the forklift witch is on GPL doesen't start. I dismounted the gas vaporizer and inside i found a black depozit and the nail with a spring was blocked, i think is from the GAS mix.
Any solution on this problem?
Thank you.
  • Posted 22 Jul 2016 15:52
  • By onose_m
  • joined 17 Mar'15 - 4 messages
  • Romania, Romania
Propalene is probably problem. Replace vaporizer. I use the same one as on clark units. As for solution to change every 1000 hours. Its your choice. But i wait till they fail. Have had some that last as long as 8000 hrs or longer.
  • Posted 8 Oct 2016 14:03
  • By edward_m
  • joined 11 May'15 - 111 messages
Only one solution fit new ,they should be changed every 1000 hrs
  • Posted 30 Jul 2016 08:27
  • By Liftkid
  • joined 2 Jun'16 - 32 messages
  • Lancashire, United Kingdom
