Komatsu FG30T-8 Electrical Problem
Hello. I am wondering if any one here can help me with a electrical problem i am having with this FG30T-8 Forklift It is running on Gas and has a Nissan H20 Engine. The Oil Pressure Light bulb had dropped out of the Holder when i was pushing it back in there was a spark when it accidentally touched the metal casing. which was surprising as the ignition switch was off. Ever since non of the lights are working there is no charge light coming on , no oil pressure light and the hour counter if also off. I have checked all fusees there are all intact. Also checked if any wires are burnt negative there also. The Funny thing is the Engine starts as normal. any Help would be greatly appreciated. Many Thanks in advance.
  • Posted 14 Jul 2016 09:39
  • Modified 14 Jul 2016 09:40 by poster
  • By kaiser_n
  • joined 14 Jul'16 - 4 messages
Hi Marc thank you for your prompt reply. I have gone back and checked every thing but cant find any thing obvious i pressed all connectors checked the fusses again but no joy.
there is no charge light coming on or oil pressure light or hour meter or the water temp gauge nothing. it is baffling.
Do you think it could be something to do with the voltage regulator may be it is blown ?
  • Posted 15 Jul 2016 05:21
  • By kaiser_n
Hello Kaiser, the current is indeed coming from 10 amp fuse (hour meter-oil pressure light-charge light). It looks to me that you have a wiring problem or a bad connection in a connector.
Regards
Marcb
  • Posted 14 Jul 2016 17:26
  • By marcb
  • joined 10 Jun'14 - 221 messages
  • ANTWERP, Belgium
