140 UNS
Hi I need some help.
I have a Atlet 140 UNS from 1998.
When you switch from forward to backward lhe forklift don't do it softly.
And I have a error code E 06.
I appreciate if someone can help me.
Best regards
  • Posted 12 Apr 2016 00:54
  • By Javou
  • joined 12 Apr'16 - 9 messages
  • Leiria, Portugal
yes wire guide antena is bad you have to calibrate the potetiometer
check your wire harness
  • Posted 20 Apr 2016 22:05
  • By GUANAJUATO
  • joined 3 Jan'15 - 67 messages
  • Illinois, United States
Hiii,
Can you help me E 104.
At start up the display shows wire break.
Regards
  • Posted 20 Apr 2016 21:34
  • By adrine_f
  • joined 13 Jun'14 - 22 messages
  • kuwait, Kuwait
Yes there is a small black steering motor. I saw the bruches and they are fine, can it be that the truck does not know the travel direction?
  • Posted 18 Apr 2016 18:34
  • By Javou
  • Leiria, Portugal
no, question? this truck have small black steering motor, if it' dos check the motor bruches, but you have 2 diferent thing one is- plug braking- 2 error code in the display, that error code 06 means is the you have steering problem,
  • Posted 14 Apr 2016 21:33
  • By GUANAJUATO
do I have to buy a new servo motor?
  • Posted 14 Apr 2016 19:40
  • By Javou
  • Leiria, Portugal
well you can erase it'' but, the computer storage the last 30 error codes
06 was the last one, is always going to show, on the display
  • Posted 14 Apr 2016 09:37
  • By GUANAJUATO
the error is all the time. do you know what to do to solve it?
  • Posted 14 Apr 2016 05:28
  • By Javou
  • Leiria, Portugal
hi javou is the truck shut down and you get error 06 on the display
or just dont go forward to backward softly, error 06 is the servo motor
and going forward to backward too fast you need to adjust the plug braking, the higher the#the softly will take off, the lower # the faster will go, O! you also need had set to to adjust the plug braking, if you dont have one you need to call a fork lift service company
good luck,
  • Posted 13 Apr 2016 22:34
  • By GUANAJUATO
Sue Tomic Sue Tomic
SMV (Konecranes) 4538CCX4
Terberg YT223
