Traction Contol Cuts Out When Unit Heats Up
I am having an issue with the control system on this truck. (Cableform) 48V
The truck shuts down after it heats up. The system will start again after just a few minutes and it doesn't give me enough time to troubleshoot the problem. I have taken the temperature sensor out of the equation by jumpering the ends together. The truck continues to cut out and I am looking for any sugestions.
  • Posted 5 Mar 2008 09:36
  • By Brian
  • joined 5 Mar'08 - 1 message
Its your ptc on the right side.
Its yellow color
Put A resistor of 150 ohm in that line
You solved the problem.
Regards.
John.
Netherlands
Clark
  • Posted 12 May 2008 04:17
  • By johngen
  • NB, Netherlands
Check the drive motors,power cables,and contact tip. If any of them show signs of overheating,or the drive motor comontators and/or field windings for shorts or burnt-up, then replace them. Next would be to check out individual components on the SCR panel,using a handyman tester.Also test the thermal protector,for to high or low resistance.
  • Posted 31 Mar 2008 04:12
  • By Truck_Tech
  • United States
Rob Ott Rob Ott
Executive vice president and chief commercial officer, East Penn Manufacturing
President, Logistics UK
Director of dealer development East Coast, Big Joe Forklifts
Vice president, customer, TVH Americas
Rob Ott Rob Ott
Funerals in Spain typically occur within 24 to 48 hours of death, whereas in other European countries they wait one or more weeks. This rapid timeframe is a cultural norm grown from the past need to manage the warm climate without modern embalming.
