lift and tilt slow code E0
Hi all could do with some advice on this little toyota, drive works fine but when you attempt to lift or tilt the hydraulics they are really slow and judder, code E0 comes on the screen with the spanner light. On first inspection the hydraulic oil level was not on the stick so put in 8 ltrs still the same. Going to remove c/weight to see if pump is seized but why would the lift still be trying?????
  • Posted 4 Mar 2016 19:06
  • By percy1977
  • joined 4 Mar'16 - 1 message
  • south yorkshire, United Kingdom
we dont know everything!!!
It is the sensor bearing.
regards
  • Posted 11 Mar 2017 19:08
  • By Fahebab
  • joined 18 Sep'16 - 61 messages
  • Niedersachsen, Germany
Main Cables ok,
isolation ok.
  • Posted 9 Mar 2017 06:12
  • By Fahebab
This code isnt in the book as the main controller was updated & new codes / features where added after the book was published.
E0 = Material handling circuit abnormality.
Main controller has detected abnormality of material handling circuit.
First thing is check the 3 main motor cables between the motor controller & pump motor.
  • Posted 6 Mar 2017 17:06
  • By Forkingabout
  • england, United Kingdom
Hello,
Same problem E0 on my 7fbmf25 today
In my manual there is no error code E0
Maybe someone knows the problem and know where to look.
  • Posted 5 Mar 2017 06:53
  • By Fahebab
