BT RRE Error List
Good morning,
Can anyone send me error codes list for BT RRE Year 2014?
Thanks for helping.
Or just help me out with error 2:501....
  • Posted 1 Feb 2016 22:35
  • By RLeite
  • joined 1 Feb'16 - 1 message
  • Vila Nova de Gaia, Portugal
You need BT Truck com software to fix this error
  • Posted 6 Mar 2024 20:17
  • By Syed
  • joined 14 May'15 - 194 messages
  • Sindh, Pakistan
swasiquehussain at gmail dot com
How i rewrite my serial number, I have cankey
  • Posted 6 Mar 2024 19:29
  • By Ganesan_Arjunan
  • joined 6 Jan'24 - 6 messages
  • United Arab Emirates
Ganesan
hello sir.
plz i need your help
  • Posted 15 Jul 2023 20:51
  • By Amine_CHAABENE
  • joined 20 Apr'21 - 34 messages
  • Tunisia
Hi send me your email address and I will send you the Workshop Handbook with fault code lists
  • Posted 15 Jul 2021 20:31
  • By Kenneth_Duncan
  • joined 22 Feb'20 - 3 messages
  • NRW, Germany
KD
Try and rewrite the Serial Nr back in again.
9 from 10 that's enough to sort the Check sum problem out
  • Posted 15 Jul 2021 20:26
  • By Kenneth_Duncan
  • NRW, Germany
KD
Hi! I am having the same error code (2:501) on a BT Reflex RRE 160. Were you able to fix the problem? I have the TruckCom connected to the truck, but i can not find what i should change. Thanks!
  • Posted 14 Jul 2021 05:50
  • By Tecnica_Lift
  • joined 29 Jan'21 - 6 messages
  • Argentina
2:501 Check sum error/The check sum is not correct.
  • Posted 3 Feb 2016 00:01
  • By denes_m
  • joined 29 Oct'15 - 20 messages
  • Hungary
Error code list would depend on the truck software version.
Various error codes have been removed / changed / added depending on which software version the truck is currently running.
You need BT Truck com software to fix this error, over to local BT Toyota engineer.
Ask for the software to be updated while they attend to your RRE.
  • Posted 1 Feb 2016 22:58
  • By Forkingabout
  • england, United Kingdom
Kai von Berg Kai von Berg
