Engine dies
I'm hoping someone has seen this issue before. This truck has the GM engine and shortly after warm up the engine dies. There are no codes in the system, oil pressure and engine temp are good even at the time of failure. We checked harness plugs to be sure they are tight and clean. Fluid levels are good. Not sure where to go from here except changing out the engine controller. I though I'd check here before doing that. Any help would be greatly appreciated.
  • Posted 18 Dec 2015 04:25
  • By Tech16
  • joined 4 Dec'14 - 8 messages
Yes, we have spark and fuel pressure is good. We're thinking that the ECU is shutting down the injectors.
  • Posted 22 Dec 2015 06:40
  • By Tech16
Have you checked to see if you are loosing spark or fuel?
  • Posted 22 Dec 2015 03:56
  • By BREWSKI
No codes. engine justs shuts down after warm up.
  • Posted 22 Dec 2015 01:11
  • By Tech16
Are there any codes coming up?
  • Posted 22 Dec 2015 00:35
  • By BREWSKI
Taylor T650L
Taylor X550M
Taylor T650L
Taylor X550M
