Emergency cushion tie change!!!
I rolled the poly off of the front wheel of my Mover brand lift. With the 3 day holiday no service calls available. I did in fact purchase a new tire and without a clue started the daunting task of changing myself. I determined that a pressed type fit was engaged by looking at the replacement tire. With the poly rolled off the truck refused to move and currently occupies space in the middle of the shop.
My floor jack does no good to lift the machine as the ground clearance is not much and removing the old rubber and changing the tire meant elevating. I tilted my boom back and stacked some iron squares under on the inflicted side and tilted forward lifting the mule, I repeated and now have the mule elivated. After removing the rubber I went to the task of fabricating a puller.
Without going into the entire process I was able to remove the old wheel and thinking that adding a bottle jack to my puller would mace a press. Only one problem the iron base i used was only as big as the wheel and won't reach around the new wheel and tire. Before I start making a whole new assembly I was hopeing to get some insite from someone who knows about little mule's.
QUESTION: How do I go about pressing on the new tire in the shop without the proper tools?
  • Posted 17 Feb 2008 15:43
  • By salvaged
  • joined 17 Feb'08 - 4 messages
  • Oregon, United States
If you are able to get the rear of the unit off the ground there is a single lug nut holding the drive wheel in place. Once you have it off make sure you press the hub with the chamfer towards the new tire, if not you will take material off the metal band inside the poly wheel
  • Posted 1 Mar 2008 02:35
  • By texasforklift
  • joined 1 Mar'08 - 1 message
I called a fellow more familiar than I on your unit , depending on the brand of drive unit, there is a cover opposite side of tire that has to come off and a bolt that comes off and the wheel/ shaft comes out as an assembly simular to some Crown jacks. I wished I had more for you.
  • Posted 19 Feb 2008 10:01
  • By roadrat
  • joined 24 Jan'08 - 186 messages
Hey Rat, It is an electric, Prime Mover CSX40 walk behind pallet jack.
  • Posted 18 Feb 2008 06:34
  • By salvaged
Sorry 'bout that, I was thinking of tire on an electric pallet jack, what kind of rig have you got?
  • Posted 18 Feb 2008 06:20
  • By roadrat
Thanks rat, How would one go about pulling the wheel from the mule to get it to the machine shop?
  • Posted 18 Feb 2008 06:05
  • By salvaged
It takes a stout hydraulic press to change those tires, Do you have a local machine shop that might help? The proceedure you are trying to use with a puller and jack sounds a little dangerous--might fly apart and hurt you. Just a thought
  • Posted 18 Feb 2008 05:25
  • By roadrat
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Taylor TXB180S
