Hoppecke Track Air - Error Code E109
Hello all, I have Hoppecke Track Air (348/090), 48V forklift charger, and it keep displaying error code E109. If anyone can help it would be great.
Thanks in advance
  • Posted 31 Aug 2015 23:21
  • By bojan_n
  • joined 31 Aug'15 - 4 messages
  • Serbia, Serbia
Hello marcb
I have read your notes for a Hoppecke air trak.
Currently i have the same error 09.
Unfortunately someone has dismantled the air pump as i bought it. Also my charger hasn't an air pump. How can I solve the problem? Any Jumper or sothat the board can work without pump.
Thanks and regards
Ermens
  • Posted 25 Aug 2025 03:02
  • By ermens
  • joined 20 Aug'25 - 2 messages
  • E09 Hoppecke Track Air charger, Germany
Ermens
Hello every body
I have the same E09 at my Hoppecke air track HF Charger year 2004.
But regarding to other answers which are located hier, my charger hasn't an Air pump system.
Can anyone help me what could be the reason?
Thanks
ermens
  • Posted 20 Aug 2025 18:04
  • By ermens
Ermens
Thanks a lot for reply, so it seems that the only solution for my problem is to find a service. That is going to be very difficulty because there is not Hoppecke service in Serbia.
Once again, thanks a lot
Best regards
  • Posted 11 Sep 2015 17:57
  • By bojan_n
  • Serbia, Serbia
Hey Bojan, Batteries with an air system has got the possibility to recharge it even when it's not for 80% discharged. So when when the driver has got a lunch break for 1 hour it is possible to do so without damaging the battery.
Normally you can remove the air pump out of the charger but then some setting has to made which is in your case impossible so I would try to put a plug (with a very small hole ) into the hose of the air pump so the pump can work with some resistance on it.
As I wrote before you have 7 times to try and then the charger goose in safety!
Regards
Marcb
  • Posted 11 Sep 2015 06:21
  • By marcb
  • joined 10 Jun'14 - 221 messages
  • ANTWERP, Belgium
You are right, the error code is E09, but I am curious, what is the purpose of air system on battery charger ? And in my case, if it is not necessary, can it be deactivated, because I can not find Hopecke service center in my country.
Once again, thanks in advance
  • Posted 9 Sep 2015 19:47
  • By bojan_n
  • Serbia, Serbia
Thanks a lot marcb, I will repair it asap.Thanks again
Best regards
  • Posted 1 Sep 2015 17:08
  • By bojan_n
  • Serbia, Serbia
Hello Bojan; if it's E09 then there's a problem with airsystem on battery (hose or connection failure) or charger. if it is repair it asap you only have that error 7 times and then you need a guy from Hoppecke!!
Error E109 doesn't exist as far as I know.
Regards
Marcb
  • Posted 1 Sep 2015 00:55
  • By marcb
  • ANTWERP, Belgium
Taylor T520M
SMV (Konecranes) 4632CC5
