Hydraulic Interlock
Hello,
Kindly Help Me For This Error Code : 524284-4 Hydraulic Interlock For Hyster H3.0FT
I will Be Appreciate.
  • Posted 31 Jul 2015 17:10
  • By KASBATIOUN
  • joined 3 Jun'15 - 12 messages
  • lagos, Nigeria
trDTC 524284-4 - Lift/Lower/Return Circuit OORL
DTC 524285-4 - Tilt Base Circuit OORL
POSSIBLE CAUSE
A. COIL DRIVER/DRIVER RETURN SHORTED TO GROUND
B. FUNCTIONAL VALVE FAILURE
C. FUNCTIONAL FAILURE IN CONTROLLERy this one
  • Posted 1 Aug 2015 01:26
  • By don_a
  • joined 16 Apr'15 - 53 messages
  • Vermont, United States
disreguard last post
  • Posted 1 Aug 2015 01:23
  • By don_a
DTC 524225-4 - Transmission Forward 1 Pressure OORL
DTC 524282-4 - Hydraulic Lift (Load Weigh) Pressure OORL
POSSIBLE CAUSE
A. SENSOR SUPPLY OPEN CIRCUIT
B. SENSOR SIGNAL OPEN CIRCUIT
C. SENSOR SIGNAL SHORTED TO SENSOR GROUND
D. SENSOR SIGNAL SHORTED TO FRAME GROUND
E. SENSOR FAILURE
F. FUNCTIONAL FAILURE IN CONTROLLER
  • Posted 1 Aug 2015 01:21
  • By don_a
Thank You BREWSKI For Ur Support.
I Discover When I started The Machine All The Function Lift/lower is Working Perfect just For one minute and After That it will Blow Amber alarm with Error Code.
I Off the Machine and Started Again lift/lower will work again for one minute.
Your suggestion Please
  • Posted 1 Aug 2015 00:15
  • By KASBATIOUN
  • lagos, Nigeria
Lift/Lower return coil reading low. Coil driver/driver return shorted to ground.
  • Posted 31 Jul 2015 22:47
  • By BREWSKI
Terberg RT403
UN Forklift FD35T
Lift Technologies Inc.
Brussels Airport in Belgium, Europe is the world's largest sales point for chocolate, with over 800 tonnes of chocolate sold annually. This averages out to about 1.5 kilograms sold every minute.
