CAT P6000 - AT13F01090 - Code E24
Hello Code E24 - Got to this unit after backyard mechanics FUBAR it
Wiring a mess but all continuity good
Had a E23 code bad ECU- Changed ECU - Now Code E24 -Tried to relearn throttle pot - 2 sec 10 sec 2 sec - Still Code E24
Looking for some more detailed service information
Suspect relay or bad Throttle Pot??
prenticelift at gmail dot com
  • Posted 25 Jul 2015 06:07
  • By Prentice
what are the procedures for the relearn or can you send me a link to where you found them? i've got 2 CAT lifts down with this same issue.
  • Posted 25 Feb 2025 06:04
  • By Tank_420
  • joined 25 Feb'25 - 1 message
How do you do the throttle pedal learn
  • Posted 7 Jun 2022 01:33
  • By Vernon_Jackson
  • joined 7 Jun'22 - 14 messages
Vernon
Need software or manual to reset pod, or explain the steps
  • Posted 22 Nov 2019 04:58
  • By Norman_Arter
  • joined 22 Nov'19 - 5 messages
  • Tennessee, United States
Norman Arter
sbhbrett,
you can try disconnecting the battery for 15 mins and see if that resets it but i doubt it will, that info is generally hardcoded into the programming.
Usually that is reset through the software and a relearn command is given using the software.
  • Posted 1 Jun 2016 21:23
  • Modified 1 Jun 2016 21:23 by poster
  • joined 23 Mar'12 - 3,693 messages
IS there a way to do the Air Idle Volume learn manually or do need to have the software?
  • Posted 1 Jun 2016 00:17
  • By sbhbrett
  • joined 18 Mar'16 - 17 messages
Ok got it - found Throttle pot out of adjustment - it was centered - moved to the old mark's (full foward)- performed the throttle learn tests again - Erased codes good to go - Thanks for your help guys
  • Posted 29 Jul 2015 03:31
  • By Prentice
one of the most common problems with the throttle body code E23 or E24 is broken wires at the plug harness.
There could also be a throttle plate linkage hanging or damaged gears in the motor causing it to hang.
Also if the battery is disconnected, or the throttle body disconnected/replaced or the accelerator sensor disconnected/replaced you must perform:
- accelerator released position learn
- throttle valve closed position learn
- idle air volume learn (fast TAS normal)
Failure to perform these learns may cause these codes to set.
  • Posted 25 Jul 2015 13:34
  • Modified 25 Jul 2015 13:36 by poster
The etc relay,3rd down can be checked by turning key to run position, if it is good you will hear the stepper motor in the electronic throttle control cycle. If it is bad take the fuel pump relay and swap it, this is assuming the truck is not dual fuel or gas powered. The accelerator unit is two different pots check 5 volt reference and ground for each pot, if you have access to a quality scan tool, ie snap on Solus Pro, you can monitor apps sensor voltage, jump 5 volt refernce to signal for each sensor, and scanner should display 5 volts. Jump ground to signal and scanner should indicate 0 volts, this is to test circuit integrity, if good replace accelerator pedal position sensor.
  • Posted 25 Jul 2015 09:56
  • By jeremy_s
  • joined 28 Mar'08 - 205 messages
Terberg RT403
Hitachi HX64B2
