Issues with used/neglected machine
So my boss purchased a used Yale ERC030AG Forklift from a "friend", and it has fallen on me to try and sort out the issues. Here's the info from the Data Plates:
Model: ERC030AGN36TE084
Serial: A814V04167W
Battery: 18-85-17 (36V)
Capacity: 680Ah
Charger: Charter Power Systems FR18CE640A
Volts: 36
Amps: 135
Cells: 18
So, initially I plugged the battery into the charger and it would not charge. Checked the battery voltage and it was at ~7v, which I figured was too low for the charger to recognize, so I jumped the main relay to force the charger on to get some voltage into the batteries.
The charger is now recognizing the batteries and starting up automatically. However, I can't seem to get the battery voltage above about 36.6v. This voltage is right after disconnecting the charger, so it will probably be lower once it's had a chance to rest and cool down. I did check the voltage of the individual cells and they were all within.1v of each other. Also, it would seem that the plates are swelling pretty badly inside the batteries. I've had to remove electrolyte twice (about 2 gallons total) because it was overflowing out of the vent caps. Both times I've taken the fluid down to the bottom edge of the internal plastic neck.
When we hooked the batteries up to the forklift, we were able to get it to move forward and in reverse. The pump for the power steering appeared to be working, but the fork controls were unresponsive, no lift, tilt, or side-shift. This forklift does have a mechanical valve body, and the attached electrical switches are functional, but I don't appear to be getting any pressure to the valve body.
I believe the batteries are FUBAR and not supplying enough voltage to engage the main hydraulic pump, but was hoping to get some verification.
I was also informed that this forklift sat around unused for about 2 years.
I am new to electric forklifts, but have a decent amount of experience with older gasoline and propane systems, as well as pretty solid electrical fundamentals.
Let me know if any other information is needed, and thanks for your time in reading this...
  • Posted 21 Jul 2015 08:38
  • Modified 21 Jul 2015 08:41 by poster
  • By JSterrett
  • joined 21 Jul'15 - 3 messages
  • Oregon, United States
i would run the battery through a couple of full charge cycles
if it does not recover enough to run the truck effectively then you will wind up having to replace the battery.
A good charged 36v battery should read in the neighborhood of around 37.5 to 39v depending on the age and condition.
Once they get so old and have been charged many cycles over the years they just wear out, batteries only have a pre determined number of cycles and that combined with the type of care or non-care it has received over the years they will eventually get to the point they will just not charge up anymore. Nothing you can do to fix that other than replace the cells or replace the battery.
  • Posted 23 Jul 2015 23:35
That machine will intentionally shut down the hydraulic system if the battery voltage is too low. All you can really do is keep charging and hope for the best with that old battery.
  • Posted 23 Jul 2015 20:34
Checked the resting voltage this morning after being disconnected all night, and the batteries were reading 36.64v. The batteries still haven't hit a good enough charge for the charger to stop charging yet though...
  • Posted 23 Jul 2015 09:10
  • By JSterrett
Quick update, tried the lift controls again (battery was at 37.1v), and they are functional.
  • Posted 21 Jul 2015 08:46
  • By JSterrett
