BE2056 fault code 47 and 56 jumping drive when hot
Hi we have a translift Bendi BE2056 mid 90s with an EV100 controller. The fault started with fault code 47 and this happened when the truck has been working and has got warm. The truck judders and then stops and when you try and restart selecting foward you get fault code 47 but if you try and start and engage reverse you get fault code 53. We have changed the rec2 and rec1, we have also changed the drive contact tips,as they were burnt. This helped for 20 mins and then the same problem came back. Any ideas?
  • Posted 17 Jul 2015 03:17
  • By leethelift
  • joined 24 Sep'14 - 7 messages
  • wiltshire, United Kingdom
Hi Leethelift
Did you end up working out the issue with this one ?
I'm having the same fault on my G4 2013.
  • Posted 24 Nov 2024 20:25
  • By Aldo_GM
  • joined 24 Nov'24 - 1 message
  • Victoria, Australia
Aldo_GM
Having the same issue how did you resolve this?
  • Posted 31 Jul 2019 18:20
  • By Scotty1306
  • joined 31 Jul'19 - 1 message
  • United Kingdom
