How to Calibrate Joystick
I have a Joystick that is off center for fwd/rev on a Cat NRR40 Ser # 2NL02419. The P-meter is pinned and not adjustable and the linkage is non adjustable. Is there a sequence of button pushing to access the screen and calibrate this joystick?? I see the line up holes that are used to center it. I appreciate your assistance. Thanx
  • Posted 30 Jan 2008 17:26
  • By TKOforklift
  • joined 24 Nov'07 - 30 messages
  • British Columbia, Canada
this is a caterpillar thread, you might want to post this in a yale thread ;o)
  • Posted 19 Jan 2018 00:33
Could I get some more information for a Yale NR040?
  • Posted 15 Jan 2018 07:36
  • By 0n331gh7y
  • joined 15 Jan'18 - 1 message
  • Alberta, Canada
actually changing out a pot and calibrating it 'learning it' is not that hard to do.
The trick is to have the machine in 'learn mode' before you begin. The reason being is that after you change out the pot you will have a very hard time getting it to go into learn mode if it is not already there so having it there before you begin helps considerably.
To access the maintenance menu's it requires pressing the horn button and the right shift button at the same time while turning on the key. This will bring you to a password menu, the default password is CAT1 or CAT2. CAT1 being the operators menu and CAT2 being the maintenance menu. These passwords may be changed at any time so if these do not gain you access then you will have to find out the password or get a cat tech with the DCAT software to reset the system for you.
Once you gain access to the maintenance menu you can use the dpad on the control handle to scroll through the menu and find 'learn' , then go to learn controls and press horn button. Once you start the 'learn mode' process it just requires you to move the handle full forward, full reverse and then recenter. The truck will beep when finished and then you exit out of the menu. The display will guide you through what to do if it is working correctly.
NOTE: if you have not done this before DO NOT attempt this without assistance:
There is also a test mode (A04) you can set it in to monitor the voltage of the pot so you can set it to the correct voltage.
The correct voltage for the travel pot is 2.0 - 3.0v (optimal setting would be 2.5v)
There is no pot for the lift/lower as it is controlled by switching and a manual valve.
IF you are not sure about anything you're doing in these menus DO NOT attempt to change ANY settings or you will cause the truck to run incorrectly or not at all and cause yourself more problems and in worst case scenario could cause the truck to make unexpected movements that could be very dangerous.
I suggest you have someone that knows these proceedures present with you the first time.
  • Posted 3 Jan 2014 21:46
  • Modified 3 Jan 2014 21:54 by poster
can you send me a copy [email address removed]
Thank You
  • Posted 3 Jan 2014 05:35
  • By phil_r
  • joined 9 Apr'10 - 21 messages
  • Illinois, United States
could you send me the information on calibrating the joystick on thecat nrr40. my email address is [email address removed]
  • Posted 1 Dec 2013 07:25
  • By brummie
  • joined 5 Feb'12 - 4 messages
My email is tkoforkliftservice at shaw dot ca. Thanx
  • Posted 31 Jan 2008 12:12
  • Modified 31 Jan 2008 12:15 by poster
  • By TKOforklift
TKO Forklift and Equipment Repairs
Kamloops BC
250-819-6575
tkoforkliftservice@gmail.com
After pot is installed, it has to be "Learned". Have an email address? Will send procedure. Menu is all done through the control handle.
  • Posted 31 Jan 2008 04:48
  • By carl_v
  • joined 12 Oct'07 - 76 messages
VETTER Industrie GmbH
JCB 533-105
Terberg YT220
