hyster H40XMS year?
How can I find the year of a Hyster forklift? I need to order some parts for it. it is a model H40XMS. It is a 4 cyl. propane. Thanks
  • Posted 24 Jan 2008 17:44
  • By racer
  • joined 24 Jan'08 - 4 messages
  • Illinois, United States
I was wondering if it could have just been that the propane was very cold. The bottle was outside in 10 degree temp. After the tank warmed up, it runs perfect now. Do propane motors run rough when it is very cold?
  • Posted 1 Feb 2008 17:11
  • By racer
Autolites rock thank god that all my company stocks
  • Posted 1 Feb 2008 12:00
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
The Mazdas love to eat rotors as well.
A bad denso plug will kill the rotor in ~1hr, I have had no rotor failures since switching to Autolites...
  • Posted 1 Feb 2008 07:35
  • By mike_n
  • Alberta, Canada
Backfire how tailpipe or intake.Tail pipe could be timimg,So could intake.Intake could also be a lean condition.Plugs have also been known to cause this.A good tune up will help if you can find one to trade on.If someone thinks its broke then they will want more boot.Outside lifts tend to bring more as they can be used inside or out solid tire lifts tend to only wat to run on hard a surface.
  • Posted 26 Jan 2008 11:59
  • By proshadetree
Thanks for the info, the last letter is a V, which should be a 1998. Also on the hour meter, it reads 37294. I beleive that means it has 3729 hours.Is that correct? I left it run for about 20 minutes and the last digit went from 2 to 4. I beleive the last digit is tenths?. Thanks for your help. I also have another question, it has been sitting for about 3 months. It idles fine but sometimes when you press the gas (when it is cold), it backfires.Would plugs and wires help this? It is propane. Are there any adjustments to the carb or any cleaning that can be done? I purchased this unit, but I really need a rubber tire one to run on gravel etc. If anyone has something available to trade, pleaselet me know.It is a model H40XMS. 129"max. lift, good condition.
  • Posted 25 Jan 2008 16:43
  • By racer
it sould have year on rating plate. uk hyster trucks have
  • Posted 25 Jan 2008 07:07
  • By kevin_k
Yep, last letter of s/n.
2008 = F, just start counting the letters it takes to get to F...
  • Posted 25 Jan 2008 02:52
  • By mike_n
  • Alberta, Canada
Also parts should be able to order with model and serial number any parts needed
  • Posted 24 Jan 2008 23:11
  • By proshadetree
Check serial number--The last "letter" will be the year--Any dealer can desifer for you or a Tech with a spec book ---Hope this helps
  • Posted 24 Jan 2008 23:07
  • By roadrat
  • joined 24 Jan'08 - 186 messages
Toyota 8FD45
Taylor TX330S
USD159,500
