No Function when key set to RUN - Full Battery
We charged the Batterie for the lift last night. When finished I just checked the battery Display if it is full, all was fine. Full battery was displayed and the machien was ready to work.
Today I turn the key and no function at all anymore.
No light, no Sound, nothing happens. Not even a click from a Relais.
I checked voltage of Batterie: 49.8V idle
When I connect bat to charger, charger does not charge.
I checked with a multimeter the power in connectors without a battery connected. Result 100 kOhm with key in off Position and 200 Ohm with key in ON Position.
Any help is welcome.
Right now I wonder if the battery with load Drops voltage so that not even the electronics works. Is that possible?
  • Posted 23 Apr 2015 05:37
  • By Furetto
  • joined 23 Apr'15 - 2 messages
  • NRW, Germany
Thanx for your help
I was wondering if the charger would start charging because of the low voltage, but I tried two charger and None of them even starts at all.
I will have to check the cells tomorrow.
  • Posted 23 Apr 2015 07:43
  • By Furetto
  • NRW, Germany
Have you got a dead cell on the battery?
The voltage sounds low for a fully charged 48 volt battery.
A failed key switch or blown F60 fuse would stop the truck powering up but I would check the battery first.
  • Posted 23 Apr 2015 06:53
  • By Forkingabout
  • england, United Kingdom
Maxlion FDR45
Maxlion FB35LI
Lift Technologies Inc.
