Stuck in 2nd gear? No low end power
I have a 2005 yale 8000lb lift I beleive. It has no low end power anymore it can't even move a wagon with steel on it barely. So far I've only checked solenoids and there's s switch with a gear around a number 1 that makes no difference. Any ideas?
  • Posted 15 Apr 2015 00:23
  • By CharlieJetson
  • joined 15 Apr'15 - 4 messages
  • Minnesota, United States
It sounds like it is engaging both directions at the same time. Try unplugging one of the directional solenoids and try moving.
  • Posted 7 May 2015 02:56
  • By BREWSKI
It will lift and act just like it should in neutral or with clutch/brake engaged. All the bog starts once it's in a gear
  • Posted 5 May 2015 23:20
  • By CharlieJetson
How does the engine perform with a hydraulic load?
  • Posted 5 May 2015 22:31
  • By BREWSKI
The valve covers say v6 vortec
  • Posted 24 Apr 2015 01:50
  • By CharlieJetson
The serial number is c813a02032y. I think its a GDP090 it is LP. It has a 1st gear lock up switch which is why i think it has more than 1 speed. The shift lever only goes forward and back one click so i cant choose the gear with that. In Neutral the forklift sounds fine and revs up quick like it should but once i put it in forward or reverse it dogs right down and will not rev up at all just kinda grumbles and barely moves
  • Posted 24 Apr 2015 01:42
  • By CharlieJetson
Does it have a second speed?
  • Posted 20 Apr 2015 22:58
  • By BREWSKI
What is the serial number of the truck? What engine and fuel sytem is in it? LP??? gasoline??? Could be a number of things from spark plugs to low fuel pressure to a dirty air filter??? Little more info please....
  • Posted 15 Apr 2015 03:35
  • By kevin_t
Briefs United States
