fault code
I have a problem accessing the dash to solve this fault code 522781-3 i think its a problem with the directional switch but now this fault code has come up i cant get into the dash to change this. Is there a way of bypassing the fault before key switch to get into the dash?
  • Posted 27 Mar 2015 18:57
  • By luke_m
  • joined 2 Feb'13 - 97 messages
  • Bedfordshire, United Kingdom
Thanks for the info swoop i had to bite the bullet and get hyster out with the laptop. All sorted in 5 mins. Cheers
  • Posted 30 Mar 2015 17:11
  • By luke_m
DTC 522781-3 - MONOTROL REV Switch OORH
check the switch, the wiring for shorts or opens
worse case scenario is the controller has failed
as for bypassing the error on startup?
don't know of a way other than hooking up the laptop
have you tried accessing the display diagnostics while turning the unit on instead of waiting for it? Just a longshot but generally the system has to be fully initialized before it will let you access the diagnostic screens.
  • Posted 30 Mar 2015 03:27
UN Forklift FBT20NQZ1
Crown CG33P5
Crown CG33P5
