hard steering only if not moving
Hello guys. I have a Yale GLP040RDNU it's a '95 truck. The steering is hard/ no power steering when truck is not moving but hydros ok. You move half an inch either fwd or rev, steering is ok. Jacked it up, ram ok/ not bent, drag link ok, king pin ok, everything mechanical ok. Overhaul steer cylinder thinking possible piston seal- same thing. Replaced orbital thinking that was it- same thing. Can't be the pump since it picks up 3000 lbs no problem. Any pointers?
  • Posted 19 Mar 2015 16:50
  • By HIlifthigh
  • joined 21 Feb'15 - 17 messages
  • Hawaii, United States
Thanks, I'll check on it. Ran out of options and not too familiar w/ Yales. Also forgot to mention, I did clean suction filter in tank and replace element.
  • Posted 21 Mar 2015 14:54
  • By HIlifthigh
I think your truck has a priority valve that delivers oil from the main pump to the orbitrol. The priority valve should be in the rear of the main pump. Follow the pressure hose from the orbitrol and see where it comes from.
  • Posted 20 Mar 2015 23:37
  • By BREWSKI
Yale Lift Truck Technologies
Sue Tomic Sue Tomic
